Anaheim, CA
3/10/2020 10:22am
Anyone run one of his 325 kits on a YZ?
Thoughts?
How did it change the power band?
TIA
Thoughts?
TIA
Thanks 904
I'm curious how they compare/contrast.
TIA
Is to promote available Big Bores, 300 or 325. I wish a 350 or 400cc was available (Probably don't need bigger)
Lightweight 300/325 cc 2-Strokes are the ANSWER for 75% of the Riders who need inexpensive MX/SX/Off-Road Motorcycles. Athena, ESR, LA Sleeve, Tom Morgan, Eric Gorr all have a Big Bore Kits that work, some better than others.
But ESR's Cylinder Kit (ESR 325 CEO kit (Mike Alessi) WON the Monster Energy Cup (MEC, LCQ), finished 19th overall), is the BEST VALUE for the Money!
In my mind, I will NEVER go back to a 250 - There is no Replacement for Displacement!
Rides by friends make the comment, who needs EFI, the Throttle response is instantaneous!
MX Tracks: At 30%+ Throttle Torque out of the turn WAY better than a 250
-Compared to a 450 it has a similar MidRange and High End (last 20% Throttle has a Kick) (Installed ESR Pipe)
-Closer to but not as much as a 450 with a very Linear power band, almost like an Electric Motor
-Way easier to ride than a 250
-Everywhere the ESR is stronger than a 250 could ever hope to be
Off-Road: Try to stall my bike you may not be able to
-Want to ride Extreme Enduro, (Installed Rekluse EXP Core with Machined Billet Clutch Basket) no problem
My Setup: Yamaha YZ ESR 325 - 2007 Model
-ESR 325, S7 Woods Porting, Silver Head, Race Gas Dome, (Use Race/Pump Gas 50/50)
-165 Main Jet and 42 Pilot Jet, Needle in the top position, Riding Altitude 500’ to 4,000’
ESR 325 Mike Allessi WINS - Full LQC from the 2019 Monster Energy Cup. Watch Mike Alessi qualify the first ever two stroke in MEC history. 🏁🏁🏁
History was made:
First 2-Stroke Yamaha YZ ESR 325 with a Combined Optimized Efficiency (CEO) Big Bore Cylinder Kit to make the Monster Energy Cup Main Show (Finished 19th) and Hole Shot in the LCQ against Performance/Factory 450’s.
https://www.youtube.com/watch?v=0ffMMQmETm8#action=share
https://youtu.be/0ffMMQmETm8
MEC - Complete LCQ Race - Ricky C. can't believe it, he does not have much to say!
“Small manufacturing businesses drives the US Economy”
Manufacturing isn’t just for large businesses. In fact, 98.6% of all manufacturing companies in the United States are small businesses and the majority of them have fewer than 20 employees.
When looking at the relationship between manufacturing companies and how many employees there are, the vast majority of manufacturers have very few employees.
According to the Small Business Administration’s latest data:
• 355,467 manufacturing companies have ----------""""""""““NO””"""""""""""-------------- employees.
• 187,862 manufacturing companies have between 1-20 employees.
• 60,099 manufacturing companies have between 21-499 employees.
• 3,813 manufacturing companies have more than 500 employees
Overall, 75.3% of manufacturing companies have fewer than 20 employees.
Yamaha 1999-2020
Honda 1992-2001 & 2002-2007
“In my Mind” With a YZ ESR 325 cc you ONLY need “1” Bike
Broadest (Linear) Power Band for Motocross & Off-Road riding!
https://www.eddie-sanders-racing.com/product-p/yz325.ceo.cylinder.kit-…
The C.E.O is a revolutionary design to the modern 2stroke motor. The design has been worked on, developed and redesigned many times since the 80’s when ESR first tested it. Don’t understand it? Well here is a quick laymen’s description of what’s going on. On a 2 stroke during the up stroke fresh fuel/air is pushed out the exhaust. It’s the expansion chambers job to push that fresh charge back into the combustion chamber. This is where matching the pipe to the porting is so important. With the C.E.O. dished piston top, instead of pushing that fresh charge out the exhaust it forces it into the center of the piston. This is optimizingthe efficiency of your fuel/air charge when it’s “off the pipe” allowing the motor to still run optimal even when your not in the Goldilocks zone of the pipe and porting matching perfect. This drastically broadens the power band, and truly turns your big bore kit into the “4 stroke killer”
https://www.eddie-sanders-racing.com/product-p/yz250-325-big-bore-kit.h…
So show us your Ugly bike, even though I haven't seen it I know it's Ugly!
Post a reply to: Eddie Sanders
