Washington, IA
3/23/2018 3:55am
1994 CR125 shock rebuild I dropped the shim stack and wondered what is the correct order for reinstallation. Thanks
For instance, the 40mm OD are the face shims/low speed from the compression side of the piston and will most likely be .20.
https://m.vitalmx.com/forums/Tech-Help-Race-Shop,42/stack-shim-sequence…
Post a reply to: Dropped shock shim stack CR 125
