Athens, GA
4275th
7/26/2018 11:48am
How is the bushing pictured below supposed to fit in relation to the case surface? It almost looks like it's not pressed far enough in (sits about .5mm to the left of the case surface). Or, will it slide where it needs to be when I pull the case halves together? This is in a 2007 KX250 two stroke.
Whatever you do though don't press it in too much, the seat on the back side is super thin, I ruined a set of cases by pressing too much and breaking the cases.
Post a reply to: Drive shaft bushing alignment 07 KX250 2T
