Hi guys, i need your help. I am build a kx250f 2013 for mx and i have couple question that i need answer.
This is my setup:
- ported head with copper valve seat (5 angles)
- Pro-Circuit camshaft
- kibblewhite titanium racing valve spring kit
- delwest titanium valves flat face (intake&exhaust)
- stock throttle body with stock injector
- wiseco 14:5:1 piston with DLC wrist pin
- Pro-Circuit ti-6 full exhaust
- stock oem crankshaft
- full polished transmission
- hinson complete clutch
- Evans coolant .....
- Shell rotella t4 15w40
My big question is , am i need to run with race fuel ? If it's mandatory which fuel should i use? Vp , sunoco.
2nd question: May i compensate the lack of octane with octane booster like Torco accelerator ? The best pump gas that we have here is 94 octane but he have approx 5% of ethanol inside.
3rd question: do anybody find a weak point To my build and have any advise for me?
I am building it for fun, i'm not an expert. I ride here in Montréal canada at sea level .
Thank's in advanced.
This is my setup:
shell 91 is ethanol free even on east coast, its best pump i have found.
with the flat face valves boosting compression
pro ciruit cams
14.5:1
sea level (full air density)
yes you need race at least a splash fuel. a hugeeeee factor in what fuel you need is ignition. You didnt mention anything so i assume stock ignition. which puts it at a gamble on pump vs race with your specs. Can you get your hands on av gas from local small airport? if not vp t4 u4.4 great choices (t4 much cheaper but not oxygenated)
and if you decide you need race fuel, take full advantage of it with a vortex ignition or send your stock ecu to twisted development.
I'd also spend a little more on a better oil. Maxima makes a number of good synthetics. I run Rotella in my kids bikes, but not in my Husky. 14,000 RPM baby.
Post a reply to: Do i need to run my bike with race fuel?
