Twin Falls, ID
2/24/2021 6:42pm
So this bolt needs to come off so I can slit my cases... is it reverse or normal thread? Is connected to the crank so I’m guessing it’s reverse threads? I tried heat. A little impact but not to much as I’m not sore the way the threads go . Please help vital
I generally break this nut loose prior to removing engine from bike with a impact gun. As I don't have the special holding tool, I thread a little climbing rope in through the spark plug hole to keep the piston from turning over and hit with impact wrench. Some folks will jam something like a flat head between gears to keep it from moving, but in my experience its a good way to chip gear teeth or do other damage (not recommended). If you don't have the holding tool, not too tough fashion something up that wont do damage.
Post a reply to: Damn husky bolt
