Warwick, NY
6/14/2021 2:43am
I see zinc and nickel as anodes used for the process.
The engine hardware (case bolts) in particular would use nickel to bring the stock look ? I have seen zinc used in many you tube videos and they look like they have the gold type finish.
I would be correct in using nickel for a stock look ?
God knows I have 40yrs worth of bike hardware and the vinegar, salt and a couple batteries can't be more than 20 bucks total.
If anyone has done it and can save me the experimental time, I would be totally down with that.
Otherwise I'll do it and reply with my results
For big stuff like linkage bolts or whatever, I would send it out to a proper plating shop. But for hardware like case bolts, save yourself a ton of time and get the Nickel Wurks stuff from Spec Bolt.
https://specbolt.com/nickel-wurks-bolts-2/
The dull spots on the axles are from being rusted bad before plating.
All these parts are from 2 different bikes.
The absolute way to go.
On the left is before i cleaned them and on the right are the clean bolts before zink plating.
Post a reply to: DIY electroplating
