Shelby, NC
I am restoring a 1988 cr125 and had the crank rebuilt, new crank bearings, new transmission bearings, new cylinder, new head. Everything. Well when I put the cases back together and spun the crank I noticed it was very hard to turn. I split the cases again and pressed in the crank bearings more. One went in a little more and the other didn’t. I put it back together and it was a lot easier to turn but still wasn’t just spinning like crazy. I could turn it with my hand no problem but sometimes it would get stuck on the bottom. I’ve read post about them not being in all the way but people were having to turn it with a wrench. It’s not near that hard to turn. But it was a little stiff. My friend said he had his yz250 done and it was like that. The shop said the ball bearings just needed to break in a little. Like I said, it wasn’t a crazy resistance that requires a wrench but I couldn’t just put a little pressure and it spin like crazy. What’s y’all opinions? The motor is now completely assembled and I would rather not go back into it but if it’s messed up then I guess I’ll have to. I pulled the crank into the case halves also. Heard that can be an issue. I’ve put a crank in but didn’t replace the crank bearings when I done it. Apparently new bearings is what can cause the stiffness? Thanks. Sorry for the long description.
I was told to take a dead blowhammer and whack the end of the crank to “set” the crank in the bearings. It helped a lot.
BUT, Since youre snagging up it sounds like a bearing isnt straight in the bore
crank should(must be buttery smooth). Crank trueness(word?) and lots of other things. Heating the cases and freezing
the bearings is a must! Cock those bearings in the slightest, and you will score the bearing bore. Properly heated and
frozen(I'm not talking red hot)(if I know I'm going to do this at home, I put the bearings in the freezer overnight, wife
loves this!). Then heat the bearings and freeze the crank(repeat). The bearings should just drop right in their bores.
The crank assy. also. And if you are going to tap on the crank-put the nut on it! BTW-this is standard practice. Do all
of your "adjusting" while its hot/cold(ie quickly). If this were mine, STOP and investigate. Starting with the crankshaft
out. But then, there is always wrong parts, missing shims/washers on and on. Lastly, just because someone has a
"respected reputation" doesn't mean he can't make mistakes. Get ready to buy a new crank and bearings..at least.
No power tools should ever be used on a motorcycle. Nor anything other than a plastic mallet. Get an accurate torque
wrench. Do not do this without a shop manual.
and check the over all width maybe the crank is to wide and the cases is hanging it up making the crank hard to roll over
Stop.
Take your motor to a QUALIFIED MECHANIC.
You are out of your depth.
Better?
Post a reply to: Crank harder to turn
