Knoxville, TN
rucka356
11/23/2019 8:21pm
11/23/2019 8:21pm
When I put my cases together the crank would not hardly move so I split the cases again. Now the crank bearing is stuck on the new crank(no bind). Do I need to pull bearing off when I reinstall left side case or can I use crank puller tool and pull together just is I would if bearing was in case?
Post a reply to: Crank bearings- reinstall
