- Pick trends
- Create a private league
- And more!
Find someone local who can fix the weld. Should take them 5-10 minutes.
A friend of mine is certified in many aspects of welding and quoted me $120 to repair a small crack in my PC Ti5 header pipe. He explained the process to me after i nearly cussed him out for the high cost. Its not a quick weld job like steel or aluminum is.
Especially if he didn't have / had to make plugs for a back purge set up, and (he had to) clean out every skerik of carbon etc in the header. Set up and Prep takes the time. And, is so important. The weld itself, there's no real difficulty to it, at all. Ti's a lovely material to weld.
Though, I've found that once Ti cracks, it has a tendency to crack further, be it at the repair point, or, elsewhere, so it can be an ongoing / recurring problem. If you've a system that has a bolted head / header junction, with a clamp at the header / secondary junction, you can help with longevity by running the engine / header to temperature, Then tightening the clamp.
Post a reply to: Cracked header pipe on kx450f
