IT
12/9/2020 3:59pm
Hello,
I had a look on the forum searching for a working technique to repair a bad crack in the tank of my 2013 KTM Sxf 450, but I didn't find anything encouraging.
The last post is from 2017, so I'm hoping some new magic glue appeared on the market in the meantime.
As you can see from the picture, the crack is where the tank is bolted to the frame.
This weekend I'll try to fix it with the help of a fiberglass based marine putty, like you see in the (italian) image.
Does anyone has a better solution?
My only current alternative is a used EXC tank as I can't find an SxF one, but of course the look is different
If someone has a used SxF tank, you're welcome to make me a quote.
Thank you
Thank you
I also believe it happens from over tightening that bolt.
Thanks
You will not get any seal to hold as they are petroleum based as is gas.
I would plan on doing a tank replacement.
Will post an update when I ride it, guess in around 10 days looking at the forecast
Post a reply to: Cracked KTM tank repair
