Shelby, NC
2/6/2020 2:29pm
Went to install my countershaft bearing and it didn’t go in all the way with the sweating method. Well I have a press and decided I would just press it in. Well the stator case half is not level so I put a piece of aluminum where the sprocket would go. Well there was a little bit of “uneveness” but I figured it wouldn’t matter cause it was so small and that bearing shouldn’t take that much pressure. Well it started to take more pressure then I figured so I backed it off and looked and this is what I found when I knocked the bearing out. What do I do now? Can I take it somewhere and they fix it? Or do I need a new case? If I need a new one, does anybody have a left side crankcase that would fit a 2013 yz250? Stupid move on my part. Was in a hurry and this is what happens.
Best method is heat the case, apply grease to the outside of the bearing and tap in with a socket and deadblow. Do not use a press because you cant feel the force youre applying. It doesnt take much to apply tons of force. Youll never apply that much force with a hammer and socket.
To get yours out youll have to get a blind bearing puller or grind it out.
Post a reply to: Countershaft bearing installed crooked (yz250)
