Copper head gasket sealant- follow up question
FWYT
San Diego, CA US
Edited Date/Time 5/28/2020 9:15pm
Short version: if you have played around with copper head gaskets, what is your preferred sealant? Any other tips? Do you anneal the new gasket before initial use?
Long version: I'm rebuilding my nephews YZ144 while being gainfully unemployed. It uses an Athena cylinder and head. We've been having crap luck with the Athena gaskets with a base gasket being visibly defected when new and a head gasket leaking on the initial start up. Reading some other forums and it seems there are other people dealing with their crap gaskets as well. Just as frustrating is that we have to buy a whole gasket kit and can't just get a head or base individually. Argh!!!!
We can use an OEM YZ125 base gasket and I've ordered some custom cut copper gaskets for the head. With a material thickness of 0.050", that should put us in a proper squish of right around .98mm - 1.01mm so we're good there. (We'll be running VP110) If this all works out, then pulling the top end will be easier and cheaper on the gasket side of things!
However, I've been reading that you still need to coat the gasket before use and am looking for some tips. Do you have a favorite sealant? Also, do you anneal the gasket even when new? What is your preferred annealing method?
Thanks!!
JMCR250
Chesterfield, MO US
5/26/2020 7:34am
I'll second the Permatex copper spray. I started using it on vintage water-cooled bikes a few years ago when I was experiencing some slight coolant weep. Just follow the instructions and it works very well.
A long time ago, I would anneal copper head gaskets a time or two. Always seemed to work OK, but those bikes (mid-70s MXers) were not as highly stressed as today's bikes. There should not be a need to anneal a new copper head gasket -- only after a rebuild.
FWYT
San Diego, CA US
5/26/2020 7:45am
Thank you both!
KX500
Chester, IL US
5/26/2020 9:03am
'I'll second the Permatex copper spray.'
I'll 3rd that
UGOTBIT
Upstate, NY US
1724th
5/26/2020 11:44am
Anneal new gasket, and use copper spray.
Old timers told me silver spray paint can be used also due to the aluminum in the paint?
FWYT
San Diego, CA US
5/28/2020 9:18pm
All you guys that have used the Permatex copper spray- did you have any sort of lifespan issues?
Meaning you assembled everything and you were good till for 20 hours, or however long. You didn't
feel that after a certain amount of time you had to re-apply the stuff or anything?
Thanks!
slipdog
Nor Cal, CA US
5/29/2020 6:33am
Used copper spray on most of my 4-stroke race engine builds over the years and never had a problem.
JMCR250
Chesterfield, MO US
5/29/2020 11:55am
Same here. Never an issue.
FWYT
San Diego, CA US
5/29/2020 6:58pm
Thank you, all!
Post a reply to: Copper head gasket sealant- follow up question
