VA
4/8/2018 6:14pm
What different methods do you guys use to clean your bike , i have been spraying my bike down with a little cleaner mixed with water in a bottle and then power washing . but im seeing my buddies bikes and their cases and overall bike looks so much cleaner then mine .
Step 2: foam cannon & let it soak
Steo 3: rinse soap off
Step 4: scotch brite pretty much any aluminum thats visible: especually the frame.take a rag and get the wheels and other spots the pressure washer missed
Step 5: SOS pad the seat and other areas that need it. Also wash the chain
Step 6: rinse again
step 7: maxima sc1 the shit out of it. Lube the chain.
Steo 8: clean the air filter & prep the bike for the next ride
Soak entire bike with simple green cut 50-50 with water. Wash using an automotive soap(whatever is on sale at Autozone). Rinse with hose.
Apply SC1 or other silicone based spray to the entire bike. This really helps keep dirt from sticking to the bike.
I only power wash if the race was some sort of mud bog and the hose wont take it off.
I no longer remove side panels/tank etc, use any brushes (except a tooth brush on the chain if I want it looking like new) and certainly don’t use a pressure washer. (Pressure washers are bike abuse. This fact is beyond debate)
Hose thick dirt/mud off with garden hose.
Using your prefered method spray a rich mix of CT-18 and water over the entire bike. (I use a pump up weed sprayer)
Leave the bike to dry, overnight is good. (Recommended in the instructions. Yeah, I was skeptical too.)
Spray bike with garden hose. Dirt falls off. (Quite amazing)
Chamois if required.
Be happy.
It doesn’t rejuvenate neglected bikes like some of the above, but I wash my bike after almost every ride, because it’s easy.
I use a regular hose
-spray bike
-spray soap
-wash with mitt
-rinse
-clean chain and other specific parts
I wouldnt worry about bearings too much. Theyre all sealed up. As long as you dont put the nozzle right at the seal youre good.
I do want to try shout and the red scotch brite though!
Rag and soap
Pressure wash soap off
Hit the wheels with rag and soap
Pressure wash that off
Clean chain
Get the gas blower out and dry (this gets funny looks)
Check air filter
Spray on sc1
Lube chain
Open beer
Wipe sc1 off
Post a reply to: Cleaning your bike
