Elk Grove, CA
calcoast
6/30/2018 8:51am
6/30/2018 8:51am
Hey, was just curious on how you guys clean your cranks?
I have the cases split on my 98 YZ250 and I want to clean the crank. Should I soak it in kerosene? Use soap and water and then kerosene? I don’t want the bearings inside to dry out so maybe spray with wd40 and then some oil?
I’m waiting on the transmission bearings so I can’t put everything back together right after cleaning.
Thanks
Thanks
Post a reply to: Cleaning the crank itself.
