- Pick trends
- Create a private league
- And more!
If you want to be thorough then seperate them clean and reassemble. This is the way i do mine. Not that big of a deal.
It takes more than one bottle of oil too. Also Honda sells the same oil a lot cheaper than Kawasaki. A15-00
They run $127.95 + shipping, but I'll sell for $95 shipped. SUPER DUPER handy. Makes me feel waaay better about grabbing the forks correctly / no damage. Easier than vise in my opinion. Way quicker, too + fits in your travel toolbox.
http://www.drcproducts.com/tool/sus/ed59/ed59_37_260.html
You don't have to pull the seals and bushes out but you will want to remove the entire damping assembly. This is important when it comes to refilling. You have to pump the rod and that's a pain if it is still assembled with the spring in place.
The below tool is required to get the damper split to change the inner oil.
Below tool will remove the top "nut" and the fork end of the tool will help hold the damping rod while you get the lower adjuster off so you can remove the damper.
Post a reply to: Changing fork oil
