Chain/Oil/Oil filter.
8/26/2018 10:47 PM
Edited Date/Time: 8/26/2018 10:47 PM
Hello I own a 2005 CRF450R and she need some fresh oil. Which filter and oil do you recommand?
Also need a new chain but can someone explain me the 100, 106, 110 and stuff like that? I need to select an option before buying and I don't want to buy the wrong stuff. I'm buying on Fortnine since I'm Canadian.
Thank you!
8/27/2018 3:12 AM
Oem filter and maxima 530mx synthetic oil or amsoil full synthetic. Just run the stock chain size but go with RK or DID.
8/27/2018 6:01 AM
I love shell rotella T-6 run it all my bikes after break in, never had an issue with it... I’ve also ran ATF Type F in the trans side of Honda’s with no problems... and I second the OEM paper filter elements and DID chain...
8/27/2018 3:38 PM
In the trans? What do you mean like you can't mix both oil, sorry if I'm dumb but I really want to be sure.
8/27/2018 5:32 PM
Edited Date/Time: 8/27/2018 5:33 PM
05 crf450’s have a case design where transmisision oil is separate from the engine oil... you have two fill ports and two separate drain plugs
8/27/2018 6:42 PM
OEM filter, HiFloFiltro, K&N, Twin Air, Emgo, Fram, ProFilter...Whatever you can get cheapest; Changed every other oil change (hopefully you're doing oil changes quite regularly since that generation CRF has low, appx 700cc in each side, oil capacities).
Trans:
Engine:
Regarding chain info, the length (114, 116, 118, 120 typical links for Moto bikes) depends on what you're running for gearing. I go 14-52 on my 2008 CRF450 and just get a 120 and cut it down. Splits the difference between 13-48/49 options and helps handling as well. Also, never skimp out on a quality chain: DID, Renthal, RK, Regina, EK, Sunstar (MXR1 one of the lighter non-oring options) all make solid gold chains.
