Chain Links
UPSman334
Rock Creek, OH US
I recently switched from a 50 tooth rear sprocket to a 49. Will i have to take one link out of the chain to compensate? Or can i just put it back together how it is
dkurtd
TN US
1/7/2019 7:01pm
Depends upon how much you have remaining on your chain adjuster. If your rear wheel is pretty far forward then you may not need too.
Paw Paw 271
Benton, LA US
1/7/2019 7:09pm
Remember that you may have to take two links out as you can't just take out one unless you plan on using a half link.
opyguy
Boston, MA US
1/8/2019 7:13am
i have the same bike and had to remove a link (per above, its actually 2, cant remove just 1) when I put on a 49.
barnett468
Wildomar, CA US
1/8/2019 9:00am Edited Date/Time 1/8/2019 9:03am
removing or adding a full link will move the axle approximately 5/8" using the same size gear.
changing the rear sprocket by 1 tooth will move the axle aound 3/8".
AJ565
San Antonio, TX US
1/8/2019 2:58pm
I didn't when I dropped from 50 to 49. It does move the wheel back in the adjuster a lot though, which helps out the stability some.
Post a reply to: Chain Links
