Chain was adjusted to tight? I've also seen cracked case around drive shaft bearing from tight chain. Replace the stretched chain before you end up replacing engine cases from. It can also be from new chain riding over worn out sprockets.ALWAYS replace sprockets when replacing chain.
Post a reply to: Chain
