I just adjusted the height on the needle. Is this causing it to pour gas?
Make sure your gaskets are good on the carb. I had a torn bowl gasket on my cr125 and it poured gas. Also make sure the float isn't stuck. If you haven't solved the issue already.
If it's coming from the tube on the bottom of the float bowl you either A) Have the float adjusted wrong and have to much fuel in the float bowl, or
Your float needle is sticking.
If it's coming from the tube on the bottom of the float bowl you either A) Have the float adjusted wrong and have to much fuel in the float bowl, or Your float needle is sticking.
Post a reply to: Carburetor leaking
