Cam chain 2016 KTM 250 sxf
3/10/2018 3:16 PM
So what is the trick for changing the timing chain. Unable to pull sprocket from crank or balance shaft. Photo
3/10/2018 3:22 PM
Well what do you know. I figured it out. Got to drop chain into engine case. Then pull counter balance shaft up and turn so weights will clear crank gear.
3/12/2018 9:33 AM
Edited Date/Time: 3/12/2018 9:33 AM
Does anyone know if the cam timing marks point to the center or to the outside? Just seem to be paint marks.
3/12/2018 9:58 AM
Edited Date/Time: 3/12/2018 10:00 AM
They point at each other to the center. Also keep an eye on the 3 dots on the gears also
