IS
11/29/2021 7:42am
Ok I got a 2006 CRF250 with a blown engine, changed the crankshaft, piston, cylinder, exhaust valves, spark plug, valve clearances are ok, the carb is like new inside and it has the stock jetting settings according to my location
The bike is not starting up with the kickstart, it is possible to push start it but it won't kick over, backfires sometimes when kickstarted... i know theese bikes are hard to start but this is driving me crazy..
the timing is good and it has spark..
Any ideas ?
Any ideas ?
for some reason there is a trick to start every bike I own...when people ask to ride one i always say "if you can start it you can ride it"
96 cr 125 -we little bit of throttle and 2 or 3 very quick kicks
2014 crf 450 - prime that feul pump with a 1-2 slow kicks then 1 big quick full kick
73 rickman montessa- usually a quick hard wack on the kicker with no throttle, if really hot hold the throttle wide open and kick until starts (learned this one from some old-timer flagging at the vet national highpoint when i wrecked and it wouldn't start) he came over ans said hold that badboy wide open and kick away sure enough she fired right up and off i went to finish the GP.
99 - kx 250 - starts first kick every time (this is a hell of a trick) haha its my loaner bike by the way.
sorry for the no help...
Post a reply to: CRF250 problem
