CRF Lower Fork Tube Diameter?
I want to put an O-ring on my lower fork tube to gauge travel. What’s the diameter on the newer 49mm forks the late model CRFs come with?
Yes, I’m aware that a zip tie will work but I want to use an O-ring. Thanks, guys.
zb658
Hammond, LA US
2/6/2019 12:48pm
You answered your own question. 49mm
zb658
Hammond, LA US
2/6/2019 1:32pm
Nahh i had the same confusion once upon a time. If you get a set of calipers and measure the outer tube, its like 10-12mm bigger than inner tube depending on position (upper and lower clamp area) on the outer tube.
mx317
TN US
2/7/2019 11:42am
Turbojez wrote:
People really use zipties for it? Damn...
I have seen it even on coated lowers, both on Mx and trackday roadracers..Sick
I personally use an o-ring, but it's not like the zip tie slides up and down. It only gets pushed down one time. Even if you go deeper into the stroke on the next hit it just gets pushed down a little further. No harm.
Post a reply to: CRF Lower Fork Tube Diameter?
