I have an 06 CR250 and the slide on my Mikuni is all broken at the bottom so I was just going to go ahead and do the Keihin conversion.
I have a few questions. First, does it use the same throttle cable? Second, does the TPS plug right into the CR plug? Lastly, does it use the same reed boot?
I plan on buying it through JD Jetting so I can get the JD jetting kit. Does the kit include tips on jetting if you have an aftermarket exhaust, or is it only for optimizing factory specs?
TIA
