Does anybody know where you can buy these radiator hose heat sheild jacket things? Can’t find them anywhere
CarlinoJoeVideo wrote:
Just find a larger diameter hose. I doubt that’s a specific part made for that.
They do make those I just don’t know where to get them. That’s a picture of it.
Yep, or even one of the same size that you simply slice to install over your current hose. There are also various types of wraps one could use I believe
Edited Date/Time:
https://www.heatshieldproducts.com/moto/powersports-heat-shield-sleeving/powersports-fire-shield-sleeve
https://www.amazon.com/Heatshield-Products-210043-Sleeve-Shield/dp/B0051UPW70/ref=sr_1_3?s=automotive&ie=UTF8&qid=1510548714&sr=1-3&keywords=fire%2Bshield%2Bsleeve&th=1
I've been scoping this product as well, but not sure what size to get....3/4" or 1"
PS: *Coolant hose
PS: *Coolant hose
Yeah those look good! I might get some, hahaha
DEI makes that. Check with JEGS/Summit racing. I used that stuff on a turbo car build. The oil feed line for the turbo litterally was 1/8 inch from the exhaust manifold. Worked great. Use a little heat shrink on both ends for a clean tidy finished look.
