SE
2/27/2018 6:08am
Hi! I bougt an full brembo front brake setup for my YZ due its poor brakes.
The seller said it was from some kind of Husaberg or KTM, he wasnt sure but i got it cheap so. Im missing both the lever and the adjusting screw and pin thats between the lever and pushrod.
Can you guys help me to identify wich bike it came of from, year and so on so i can get the right parts?
The numbers that i can get is;
On MC;
3 10 7676 and 01 in the circle
On Caliper;
22.5381
On Caliper bracket;
22.7610.00 and 01 in the circle
Can it be an 01 due the number in the circles?
Thanks!
On MC;
On Caliper;
22.5381
On Caliper bracket;
Thanks!
By far the easiest thing to do, is to take the caliper and master cylinder to your local KTM dealer and let the parts guy get you everything you need by matching it up. In my case, he took one look and knew what part numbers I needed for seals, levers and pads. You also have the benefit of using OEM spec parts, which were a lot cheaper than I thought they would be.
Caliper, 2000-2008, although the caliper was same in the 90s as that one as well.
So look your parts up for a 2008 ktm and you'll be fine.
Can you post some pics of the lever/MC connection? If there's a barrel next to adjustment on the lever it's the same as mine and any 00-05 (possibly newer) lever should work. They are easy to recognize due to pretty specific shape:
Post a reply to: Brembo Master Cylinder and Caliper identification?
