Venado Tuerto
AR
1312th
Hello guys, as the title suggests, I cannot brake tap mid-air because it causes my bike to stall. I have a KX450F and have ridden a YZ 250, and on the Yamaha I can do it perfectly without any problems. The real issue is I cannot have the amount of free play at the lever that the manual asks for and have the clutch set up correctly so it doesn´t stall at the same time. I am worried reducing the amount of slack will burn my clutch, but I´m pretty sure I would feel it is slipping before burning it completely. Suggestions?
Eventually had some hard times adjusting the core exp when it was under heavy load in deep ripped dirt. I transitioned back to manual Hinson clutch and learned how to pull in the lever.
Also you mentioned being pretty keen on measuring your slack to the manuals spec. When you ride the clutch heats up and you will get more and more slack and sometimes you need to adjust it in the middle of riding. Just don’t forget to put it back when the bike cools off.
Post a reply to: Brake tapping and stalling the engine
