Watertown, NY
I installed a Galfer 270mm oversized brake rotor on my bike and also installed a new set of Galfer brake pads like they suggest to do with the new rotor. I installed everything like it says to but no matter what I do the rotor seems to be rubbing on the brake pads. I made sure several times that the front tire was set right and still seems to rub. Is this a normal deal until I get some brake in time with the rotor and pads? Seemed like a pretty straight forward deal and this was the last thing I thought I'd be having an issue with. Any ideas?
Worn brake pad pins?
Is the drag continues or intermittent?
The unit you installed is new or used?
Have you checked the rotor for run out?
Try taking a syringe and removing fluid from the master cylinder until it's at 1/3 up in the window. That's a good first step to rule out overfilling as an issue.
I’ll take some fluid out and see what she says after. Thanks for the input!
Post a reply to: Brake rotor issue
