Augusta, ME
4/30/2020 4:31pm
2019 YZ450F
Replaced both brake lines with Braided.
Couldnt get pressure on either.
So i did reverse bleed. Both lines have fluid fully in them. No banjo bolts are obstructing flow.
Ive flick the levers till I stop seeing bubles in master Cylinder.
TO NO AVAIL. STILL NO BRAKES NO PRESSURE.
WTF AM I DOING WRONG?
THANKS FOR YOUR HELP!
Did you us the correct fluid?
Did you use the copper crush washers?
Got plenty of brake fluid passing through line. It seems to me its at the M/C . Bike is new. Like 5 hrs on it.
No pressure at handle or foot lever *front& rear brake*
Ive pushed caliper pistons in too in hopes of removing air.
Got no idea. Older bikes Ive had , never had this issue.
I read the manual. I made sure I had plenty of fluid in my hoses. I did cause I did reverse bleed as my final attempt before bed.
The service manual says if after bleeding and you still have no pressure to let bike rest for two hours. Well, i gave it all friggin night!
First thing this morning. I started rear brakes, bled banjo bolt closest to Master Cylinder. Pump 5 times, hold dont realease and crack banjo bolt loose , re-tighten after. Do this 5 times, keeping fluid filled and COVER OFF THE WHOLE TIME. Then do banjo 5 times at caliper end. Then bleed at bleeder screw like 5 times.
THIS WORKED PERFECT FOR BOTH FRONT AND BACK BRAKES. This resolved my problem: LETTING BIKE REST OVER NIGHT WITH ALMOST FULL OF FLUID IN THE LINES.
I went to my yamaha dealership today to pick up some stuff and they said the bubbles are super microscopic and can be seen if you look closely. Its gotta set for awhile on a line or caliper change.
Thats what I did and it worked.
Hope this helps!
Hammer
Remove the caliper, place something between the pads to simulate thickness of rotor, place caliper higher than the master cylinder (tie it up there with a bungee cord or whatever), crack the bleeder and use the lever/pedal to pump fluid uphill and out of the bleeder. All air will easily be pumped out. Close the bleeder while keeping pressure on the lever so gravity does not pull the fluid back down and suck air. Remount caliper. Perfect.
Post a reply to: SOLVED! :Brake bleed, NO Pressure!
