Blown Clutch Case Gasket
11/20/2018 11:39 AM
tc 250 2015, the bike conked out on me at the track and wouldn't kick over again. I noticed that oil was seeping out from the clutch case gasket by the power valve. Would this cause the bike to not kick over?
On a side not the kick start sometimes doesn't fully retract back and gets about half way when trying to kick it (plenty of compression/full engine rebuild 3 hours on the bike), I've checked the spring it seems tight, again could this point reason to why it would start?
Thanks in advance bra's !!!
11/20/2018 3:06 PM
Edited Date/Time: 11/20/2018 3:08 PM
The leak is caused by not installing the power valve cover gasket correctly, it will not affect the running of the bike . since it's been recently rebuilt check to see if your losing coolant your head gasket may be leaking which would follow the plug , put a new plug and see if the bike starts if it does and you're missing water you're going to need to replace your head o rings and torque properly.
