Byhalia, MS
8/5/2022 6:50pm
I got a 22 rx300. Stock jetting and its a little fat. Anybody running one and got some jetting suggestions? Mostly seems a little rich in the bottom so I'm between a smaller pilot or lowering the needle. Pic of the plug for reference. Maybe 2-3 hours on the bike.
The problem you are going to run into, is that oem series needle is to short on the L-1, clip position. Even in the 1st clip position, you won’t get what you need. Those Beta’s respond really to the Suzuki NExx triple taper series needles. Take this for what it’s worth. The last Beta 300 that in jetted , It was the MX version, it was 30 degs F at sea level I used the stock 40 or 42 pilot and the stock main, 170, and just swapped the stock needle for a Suzuki NECH that I put in the #3 clip and set the air screw 1 3/4 out.
The bike work really well in those temp, so I don’t honk it could easily handle a little leaner setup in summer temps. The bike was, what I considered awful prior to the needle swap. I can’t imagine how bad it would be in summer temps.
Post a reply to: Beta rx300 jetting
