Ijamsville, MD
20hrs and stock one is getting floppy, it annoys me so much, I want it gone forever, what’s the best perch I can buy to eliminate it
He uses a pair of replaceable bronze bearings in the perch. Those bearings are spread out farther apart than the single bronze bearing in an OEM lever or the single roller bearing in all the other aftermarket perches.
Not only do they last forever, you can change the bronze bearings and the pivot bolt to make them feel like new
If its a Yamaha, the stock perch is a pretty close second to an ARC but it takes a little more work to keep it smooth and tight. I wasn't as much of a fan of a worcs connection perch on a YZ250. I never liked the ratio that much, personal preference, I guess.
I haven't used the other brands (except KTM).
One thing I like about the stock perch. Once it gets loose you can take some pliers and clamp down to make it tighter around the lever. I can make a loose perch feel brand new in 5 mins.
Interesting, I didn’t realise you could replace the bearing in the perch.
Also, I think the older stuff used bronze (Apparently they're Teflon now).
https://arclevers.com/index.php?route=product/product&product_id=4
Post a reply to: Best clutch perch?
