Pottstown, PA
12/23/2019 7:42pm
Anyone seen their base gasket “sweating” on a newer ktm 125? Bike idles fine, runs good, though I feel like maybe it lacks slightly up top. Plug color is good, though often more wet than I like to see... bike has 5 hours on it and I noticed this after about the first hour. I’m going to check torque but need to order a tool, just curious if anyone else has seen it. I’ll be replacing top end soon anyways just wondering if I could get another 5 hours out of it first.
No noises? No hanging idle or air leak symptoms? I'd run it unless you have some weird plug readings or idle issues. Make sure to check the base surface when you do your top end.
Maybe change the oil to make sure you're not getting any coolant into the bottom end(this is me being OCD).
I've been going 25 hours on my 16 125 pistons and they all look like I could go further(I think I've done about 150 hours on the bike(Full rebuild at 90 and cylinder re-plated) . *Note, depends on your jetting and fuel mix also
You mentioned you are getting 25 hours out of pistons? That seems pretty good, I honestly have only ever got 10-12 on My RM 250 (sand tracks) and less then 10 on 125s and when I took the pistons out they were ready for replacement. I was planning on setting squish and doing top end at 10 hours anyways, I just got a little nervous as I’ve never had a new bike weep like this one is doing.
If you are lacking top end overrev, have you messed around with the powervalve setting? It's changes delivery dramatically.
I ride .75 out when offroad and 1.25 out when riding more wide open on deep tracks. Right now I have HGS pipe and Akro silencer. I like this combo better, I think it pulls more top and bottom than FMF Fatty and Shorty.
The overall package is great, it's definitely tuned for more bottom than top. A fun bike when the conditions are right.
Then we went to keihin carb and STIC insert... at that point, all bets are off, lol. Once you've dialed that setup, smart carb and lectron go on the classifieds
Post a reply to: Base gasket sweating 19 KTM 125
