Bar mounts to raise handlebars? HELP
eric427
Memphis, TN US
9/25/2022 10:33pm Edited Date/Time 10/23/2022 3:39pm
I know I’ve seen Keefer say that it’s always better to start with raising your bar with mounts instead of getting higher rise handle bars. Where can you get 1 1/8 bar mounts that are taller than stock? I don’t see any companies that make them. Any help would be greatly appreciated. I want to try taller mounts before I go with taller bars.
MX558
9/26/2022 3:51am
I have a set of these I bought by mistake . They are brand new . I never even opened the package . I will sell for $ 40 shipped or a reasonable offer
hodgeseddie558@gmail.com
Luxon MX
San Diego, CA US
9/26/2022 7:44am
What bike is it for, and how much taller would you like to go?
Moto520
Schaumburg, IL US
9/26/2022 8:05am
i went 5MM taller with my Luxon handlebar clamps and it felt weird as shit.....
eric427
Memphis, TN US
9/26/2022 12:22pm
MX558 wrote:
I have a set of these I bought by mistake . They are brand new . I never even opened the package . I will sell...
Are those any taller than stock mounts? My bike is a 2019 yz250f.
MX558
9/26/2022 7:51pm
They go inside the the stock mounts as an add on I'll look on the package tomorrow
Falcon
Menifee, CA US
9/27/2022 3:17pm
Remember that raising your handlebars will shorten the reach, since the top of your triple clamp is angled rearwards.
I always used to run my clamps in the forward position to get more reach; this also raises them a little. Try it and see if you like it.
paddyB745
novato, CA US
9/28/2022 6:44am
Ride engineering makes cheap little bar mount spacers that go under your existing mounts in different thicknesses. That’s a good start.
eric427
Memphis, TN US
10/2/2022 4:39pm
Falcon wrote:
Remember that raising your handlebars will shorten the reach, since the top of your triple clamp is angled rearwards. I always used to run my clamps...
Yeah that's a really good point. I'll give it a try.
eric427
Memphis, TN US
10/2/2022 4:40pm
Oh okay nice, I didn't know they made those. I will check them out!
eric427
Memphis, TN US
10/2/2022 4:41pm
Did you get a chance to check on this?
eric427
Memphis, TN US
10/2/2022 4:42pm
My bike is a 2019 yz250f. I'm not sure how much taller I need to go. I would like to start on the smaller end.
Luxon MX
San Diego, CA US
10/2/2022 5:20pm
Our bar mounts include a 5mm spacer that you can run on top of the clamps for +5mm over stock height, or under the clamps for stock bar height. You "can" add a spacer to the stock mounts, but it's meant to be a set length so the rubber cones get a consistent amount of squish (that's why there's a shoulder on the bolt/stud).
To properly run a spacer, you need a longer bolt, which is fine, but then you have to pay attention to how much you're tightening the nut to get the right rubber cone compression. This comes at a much lower torque than what you'd use if you had a shoulder on the bolt, so it is more likely to come loose. That's OK, but you need to keep an eye on it.
Of course if you want a much higher rise, then that's a whole different story. If you're just looking for a little, then our mounts work well, or you can just run a taller bend bar and use the stock mounts.
MX558
10/2/2022 5:42pm
They don't list the rise but looks to be 10mm
Kidkawie
ქუთაისი GE
10/6/2022 6:05pm
FYI, the Outlaw Racing risers on Amazon/Ebay are heavy AF! I bought a set, took one out of the package, then threw them in a box of old parts and bought a set of high bars.
eric427
Memphis, TN US
10/6/2022 6:57pm
Kidkawie wrote:
FYI, the Outlaw Racing risers on Amazon/Ebay are heavy AF! I bought a set, took one out of the package, then threw them in a box...
Okay thanks that is good to know
eric427
Memphis, TN US
10/6/2022 6:58pm
Luxon MX wrote:
Our bar mounts include a 5mm spacer that you can run on top of the clamps for +5mm over stock height, or under the clamps for...
Okay awesome thanks for the info. I may give those bar mounts out.
rjg
10/13/2022 6:57pm
Side note to a fellow rider, High handlebars and/or bar risers affect your front end traction via body positioning. They make you lean back more than the other (lower) bars without noticing it. When you switch back after a while you will realize the effects. You do you tho.
Falcon
Menifee, CA US
10/21/2022 2:01pm
^ Another reason I prefer the forward mounts instead of the "high" option.
Rickyisms
FL US
10/22/2022 3:23pm
I’m 6’1 and run Carmichael bend and Pro tapers on a KTM, definitely agree taller bars have a huge effect on front end handling. With the shorter bars I can distribute my weight down towards the bike better, with the taller bars you push down and forward on the front end. Another good tip is to angle your bars in line with the fork offset, and then just a hair back.
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
  • Image
Moto520
Schaumburg, IL US
10/23/2022 3:39pm
I just tried going 5mm taller on the bar mounts via the Luxon handlebar holders. It completely messed up the feel of my bike. Felt like less leverage and more separation from my arms to the front wheel
Post a reply to: Bar mounts to raise handlebars? HELP
