Washington, PA
Working on a 99 kx 250 and need to replace the axle blocks. We can’t seem to get the nut loose due to the axle spinning on the other side. Tried impact gun, lubricants, etc. any trick to it before we cut it off. Maybe it bent a little and now won’t come
Loose? Thanks.
Loose? Thanks.
I used a dremel to cut the axle between the washer and axle nut on a 99 YZ400 and replaced the axle nut and washer. I was surprised it froze up on there since the bike was less than a year old. I use a little waterproof grease on them now on all my bikes.
Post a reply to: Axle help
