FL
Titan777
6/21/2019 6:34pm
6/21/2019 6:34pm
6/22/2019 6:29pm
Is it any good? (18 KX250F)
Does an oil cooler worth the money? Is it a good way to reduce overall heat from the bike, and will it perform better?
Will a Boyesen water pump cover & impeller be a better solution?
Can I put a higher pressure cap (is it even required?) without causing issues to any gaskets? (1.6 or 1.8).
Does it require after market hoses? Not sure how the system deals with higher pressure and which parts require an upgrade to overcome the increased pressure.
What is the cheapest way to run the bike cooler?
Sorry for all the questions
Unless youre boiling over or boiling your gas dont worry about it.
Oil coolers are a waste of money. Dont bother.
Which step is the high pressure cap?
After market hoses don't play any role besides bling factor?
Is the Twin Air ICEFLOW Coolant any good? (I can't get the other US known brands).
What about the Twin Air oil cooling chart? BS?
I use Evans, and really like it.
I must flush the entire system?
Post a reply to: Anyone tried Twin Air Iceflow Coolant & Oil Cooler?
