Hey guys looking for aftermarket foot pegs for my 2011 Suzuki RMZ 450 and am coming up empty? Not sure why? Most companies don’t list for the 2011? Anyone know why or who does make them?
Edited Date/Time:
RMATV lists a handful, Fastway lists some...
I see a bunch of the same OEM part numbers too if it is other than the the L1. 2010,11,12...
Raptor, pro pegs.
mxb2 wrote:
Raptor, pro pegs.
Billy I didn’t see them listed for 2011? For some reason a lot of companies even say 2011 was different. Not sure why? I don’t think Suzuki produced to many 2011’s.
Edited Date/Time:
I compared OEM part numbers and many years are the same other than the L1 designation, not sure what that means however. Fastway/PMB lists them, have to be options out there. Worst case you get the peg mounts from whatever year and the associated pegs. I bet the mounts bolt right up.
brackets/mounts show the same part number...from a 2011 to 2012+.
Went to Motosports and they don’t show for 2011. Say it’s not available. Thanks for the help
I was just on RMATV.
point being, they all will fit if the mounts are the same.
mxb2 wrote:
Raptor, pro pegs.
Call scott at motostuff. Great dude and service.
mxb2 wrote:
Raptor, pro pegs.
Thanks I will!
Footpeg and footpeg bracket parts numbers are unique for the 2011. They were the same for '08 and '09, then changed in '10. They changed again in '11 and then went back to the '10 style for 2012 and onward (I only checked through 2015).
You may want to switch over to a 2010/2012+ bracket and see if it will bolt up to your frame. If so, you can run footpegs from '10 or '12 to at least '15 with no problem.
The part number for the brackets is 41855-28H10 (R.H.) and 41865-28H10 (L.H.).
Braaapin' aint easy.
Did you ever figure this out? Iam having a similar issue. The 2011 pegs I ordered do not match the bracket.
