Farmington, MI
10/9/2019 9:32am
I always hate changing my air filters because I always get a little bit of dust in the air boot when I change them. I always make sure my airbox is as clean as possible but there is always some specs of dust and smaller bits of sand that fall from the dirty filter into the inside when I physically go and change the filter (intake? Not sure the correct term).
I think this is just my OCD going crazy but should I even be worried about this? I always try my best to make the inside of the intake boot as clean as possible before I put the new filter in but I think I could sit there for an hour picking away specs dust or sand that finds its way in there.
If its not dusty you simply need to clean it every ride. Normal conditions dont create enough dirt on the filter to have that issue.
You do want to clean what you can though. Dont let dirt get sucked in if its avoidable
So what I do is run a strip of tape over that airbox/filter junction. Then when you go to change the filter, you
first pull the tape off and that area will be clean. No crud to fall down into the boot! Works like a charm!!
Then, hold subframe upside down, or just fender down to the ground, then remove the airfilter, thence clean the inside of the airbox. Then, install a new or cleaned and oiled same filter. Nothings going to get into your engine that way.
It's extreme, but, ultimately, the one of the things removable subframes came into being for.
Post a reply to: Always get some dust in air boot when changing filter
