Tedor
SE
Edited Date/Time 12/18/2018 4:37am
Tedor
SE
11/21/2018 3:30pm
If you change the oil, do the flakes come back?
Yes they do come back, been like this for atleast 10hours
kb228
Mansfield, OH US
11/21/2018 6:29pm
Clutch wear most likely
CarlinoJoeVideo
Portland/Los Angeles, CA US
2339th
11/21/2018 10:02pm
Hummm, likes it’s not normal. I just can’t think of many aluminum parts in the engine.
Why would the clutch hub wear all of a suddden like that?
I’m worried it’s a bearing or maybe the cam chain wearing on something.
Tedor
SE
11/21/2018 11:31pm
The steering pins in the inner hub are steel. The cam chain is brand new. Smile
Radfonz
11/22/2018 12:41am
Could be big end bearing material?
Tedor
SE
11/22/2018 1:57am
I belive there should be other types of flakes if it was big end bearing, dont know what material ktm uses
CarlinoJoeVideo
2339th
11/22/2018 2:15am
But I’m wondering maybe something with install or the tensioner is incorrect. Just brainstorming here to what can produce aluminum like that, no shavings, just dust/flakes.
Tedor
SE
11/22/2018 2:22am
I agree. The flakes did begin before I changed the cam chain. Seems odd that the inner clutch hub is wearing like that too
sandman768
Saratoga Springs, NY US
11/22/2018 6:49am
Looks like case material...look for something rubbing or wearing into the cases somewhere..bolt backing out.? I had a drive gear bolt back out and rub on the clutch case to create flakes very similar.... It was not a Ktm but aluminum cases are aluminum cases....
kb228
Mansfield, OH US
11/22/2018 6:50am
Bearings are steel. Aluminum flakes from from these things: clutch, engine cases, cylinder, piston, cylinder head.
Tedor
SE
11/22/2018 7:50am
sandman768 wrote:
Looks like case material...look for something rubbing or wearing into the cases somewhere..bolt backing out.? I had a drive gear bolt back out and rub on...
Nothing is rubbing against, if something is then its inside the cases.
Tedor
SE
11/22/2018 7:51am
The only thing on the clutch that is aluminium is the inner basket, plates are steel
DynoDan22
Victorville, CA US
11/22/2018 8:16am
Wasn't ther a recall on the '16-17 350 addressing the primary nuts backing off and coming loose? I've seen this happen and rub the right side case and leaving aluminum flakes. Might wants check it out.
MX915
Central, NJ US
11/22/2018 3:12pm
DynoDan22 wrote:
Wasn't ther a recall on the '16-17 350 addressing the primary nuts backing off and coming loose? I've seen this happen and rub the right side...
Good call. Definitely look into that.
DynoDan22
Victorville, CA US
11/22/2018 5:51pm
I like your user name MX915! I've always run #915 since I was a kid. Haha!
Tuzzo123
Saginaw, MI US
11/23/2018 10:49am
Maybe try to run dedicated MOTORCYCLE oil in your motorcycle. Its designed for bikes, and Auto oil is designed for cars/trucks. Just a thought
RGaede
Albuquerque, NM US
11/23/2018 11:33am
Castrol has dedicated motorcycle oil, both my 16 and 19 kx owner's manuals recommend it.
On the flakes, i agree to look into that primary bolt, that would definatly leave those type of shavings.
Tedor
SE
11/24/2018 10:08am
RGaede wrote:
Castrol has dedicated motorcycle oil, both my 16 and 19 kx owner's manuals recommend it. On the flakes, i agree to look into that primary bolt...
Primary gearbolt already checked Smile
kb228
Mansfield, OH US
11/24/2018 10:50am
Take a look at your cams. Sometimes if the caps arent tightened right after a valve adjustment or its not getting enough oil they can dig into the cylinder head
Tedor
SE
11/24/2018 12:05pm
kb228 wrote:
Take a look at your cams. Sometimes if the caps arent tightened right after a valve adjustment or its not getting enough oil they can dig...
Already checked that too Smile
Radfonz
11/24/2018 6:27pm
Big end bearing is silver. Just sayin.........
Tedor
SE
11/25/2018 6:33am
But its magnetic I guess and the magnet on the oil plug looks good Smile still thinking it might be inner clutch basket
kb228
Mansfield, OH US
11/25/2018 6:59am
Ok so you narrowed it down to your clutch. Replace it so we stop playing the guessing game.
Post a reply to: Alu
