DE
So I recently made the switch from Sidi Crossfire SRS2 to Tech 10s. I didn't really like the hard sole and the two layers on the inside of the Sidis, because it was a little numb.
So yesterday was my first ride in the Tech 10s and I felt even number in them. Do they just require a longer break in time? They're pretty stiff and I still have to get used to the bigger size (due to the bootie). I was just wondering if I should already pull the trigger and go for SG12 or if I should give them a bit more time to break in?
Personally, I like the tech 10's.
I currently have SG 12's and Fox Instincts.
The Fox offer the most feel imo but the Gearne's are coming around but toe area is HARD!
I was considering Sidi TA because of the traditional rubber sole and that is what I used in the 90's.
Good question mxb2. I'd like to know that also. Good luck GER.
Ghost
Yes I wear a size 11 shoe and I'm wearing a size 12 in Instincts. I guess I need a 12 in Tech 10's...?
Ghost
The 10's have much better toe feeling in comparison to the Gaerne's. The Sidi's have the best toe feeling in the boots I've worn.
As an all round, protection, feeling and comfort, I find the tech 10's hard to beat.
You wear knee pads or knee braces? Ever have sciatica issues?
Compared to the Sidis they are very stiff in forward and backward motion, but maybe that will change since the sidis have about 100 hours on them.
I still use Mobius knee braces and never had an injury like that, knocking on wood
Generally, with protection comes some element of stiffness or feeling of thickness.
You have to find the right balance for you.
For me, as someone with weak ankles, I found the Sidi's to have great feel and movement, but lacked in support, protection where I needed it.
Tech10's were the best all round for my needs.
SG12 is good, but I didn't like the toe area.
Post a reply to: Alpinestars Tech 10
