Malvern, PA
Maybe I am expecting too much out of my suspension but acceleration chop with hard base hurts like hell and bounces like a champ, all other aspects like flying down hill through braking bumps I’m golden, what adjustment to the clickers do you guys suggest I try to keep the ass end a little more planted through that crap. 17 fc350 kyb a kit rear, kyb a kit front that have been valves and sprung for my weight. Thanks in advance for any and all help
Ben
Ben
The acceleration bumps are now WAY smoother, and I was able ride much longer.
He put a stiffer rear spring for my weight and backed off high speed compression. (unscrew clicker)
So I think mine was compressing too much, and riding too low coming out of corners, causing the harshness.
Make sure your linkage is fully greased, sag 105mm.
Not sure if any of this helps you, lol.
Your seat of the pants feel of whaty's going on might not be accurate as well. If you have someone come out with you and video you hitting some chop that you have problems with, it'd make it easier to determine what the bike is doing
Also what Radfonz said.
Are you the first owner of the KYB suspension for your Husky?
Call the suspension shop. Tell them what it is doing.
If they can't help you fix it through adjusting the clickers,
Almost all of them will revalve it for free a second time if they didn't get it right the first time.
Post a reply to: Acceleration chop help
