Statesville, NC
1295th
I recently have gotten a FC350. I like everything about the bike but the forks in the acceleration/braking bumps.
The front end seems all over the place. I have the pressure around 142psi, 15 out on compression and 15 out on rebound. I'm a 185lbs in street clothes with +25A speed. Has anyone gotten the fork to soak up the little stuff without sending it out?
Are you at the recommended PSI for your weight? If so, try going 2-4 clicks softer on compression and 2-4 clicks faster(out) on rebound. This will let the fork feel softer and the rebound will make it spring back faster to the top of the stroke.
You can also consider going 1 spring rate higher in PSI and try going 6 clicks softer on compression. This might give it the effect of more hold up by the pressure but less firm initially from the compression clicker.
These are just ball park ideas, hard to exactly navigate the problem without riding it.
Post a reply to: AER Fork Chatter
