A lot of oil left over in 2 stroke cylinder? HELP
Blackjack31
Shelby, NC US
Edited Date/Time 2/4/2019 9:00pm
Pulled my cylinder off to do a top end and oil lines the inside of the cylinder and my ports, underneath the piston, and on top of the crank cases in the groove that the cylinder sits. What could be the cause? My gasket was also soaked in oil. Running to rich? Bad crank seal causing the transmission Oil to be placed up top? Gasket leaking? Also had some water underneath the power valve cover. Wondering if it was leaking and got water in there and caused a “sludge” like substance with the premix. Opinions? I have photos but don’t know how to upload them
Blackjack31
Shelby, NC US
2/2/2019 9:09am
Also one of my cylinder studs was rusted bad. Another reason why I think one of the gaskets may have been leaking. 25 hours on top end
brody
GA US
2/2/2019 12:30pm
combination of a gasket and running to rich
AJ565
San Antonio, TX US
2/2/2019 4:41pm
Does the oil color match your premix oil or transmission oil? There should be some oil coating everything.
Blackjack31
Shelby, NC US
2/2/2019 7:45pm
I run yamalube so it’s dark purple, I run rotella 15-40 in transmission. The stuff under the piston and everywhere is black. Could be dirty Tramission fluid or dirty premix
brody
GA US
2/2/2019 7:49pm
can you post some pics of piston and crank
Blackjack31
Shelby, NC US
2/3/2019 9:35am
I don’t know how to post pictures. I click on photo and add the photo but then nothing adds. It doesn’t do anything
brody
GA US
2/3/2019 9:58am
looks like a combination of some piston blow by, piston is not sealing correctly, and maybe a bad gasket in the bottom, it looks like that is rotella on the bottom of piston and the crank
ktm-5
Ravenna, MI US
2/3/2019 5:23pm
I find it hard pressed to not be a crank seal to get that much oil and I'm sure it won't look like either oil being they are mixing together in the crank case and I've seen studs just as rusty and have no issues. I do clean them up when I tear it apart and if you'd like to do the same, take 2 nuts and tighten them to each on stud then use bottom nut to unscrew the stud
Turbojez
PL
2/4/2019 2:49am
Does your bike smoke too much and burn transmission oil? You could smell it in exhaust fumes.
My main suspect would be crank seal, as KTM-5 suggested.
Blackjack31
Shelby, NC US
2/4/2019 8:52pm
UPDATE: It is the crank seal. At least that’s what I’m going with because everything else is fine. Runs great so I don’t think it’s a betting issue. The good news is I was under the impression that I had to split the cases, but I don’t.
ktm-5
Ravenna, MI US
2/4/2019 9:00pm
Yup way too much oil for jetting
Post a reply to: A lot of oil left over in 2 stroke cylinder? HELP
