If this is in the wrong place, please feel free to move.
Have a feeling a know the answer, but never hurts to ask I was always told.
Motor is an 89 yz125. I'm not getting fire. I've googled, but can't really find the resistance values for this exact model (cdi/stator/plug) The closest I've found is not showing same colors of wires. I know that's not to big of deal, but before buying parts just to be buying I'm wanting to make sure. The three wires coming from stator are red/white, brown, and black.
I usually work on small four strokes(scooters, go karts with 4t, etc) On those its pretty straight forward, one lead to ground, the other to exicter coil, stator, and so on. Check resistance. After that, check voltage with motor spinning. Can I use same method on this setup to determine what's causing the issue.
