52mm Cove valve base settings
9/9/2017 3:37 AM
Does anyone have or know any good base settings for the 52mm Cone vale ? i am a 82kg rider with gear on
looking for mostly sand base setting as here in Western Australia there is mostly sand tracks. any help or advice much appreciated
9/9/2017 4:03 AM
That's hard to say because however they are set up internally with Springs and valving willl determine how stiff they are. Unless 2 sets of forks are exactly the same, someone else's settings won't mean anything to yours...
9/9/2017 4:46 AM
CarlinoJoeVideo wrote:
That's hard to say because however they are set up internally with Springs and valving willl determine how stiff they are. ...more
get what your saying just looking for some idea of a base setting i can go from there.
thanks
9/9/2017 11:26 AM
I'd count how many clicks for rebound and compression when they are all the way soft, then start in the middle.
I start mine at around 12 out from full hard.
