Hey evryone, I have a question regarding the OEM 49mm Showa forks that come stock on the:
2018- Current Suzuki RMZ450
2017- Current Honda CRF450R
2019- Current Kawasaki KX450
Does anyone know if the top tubes are the same between the 3 bikes? I know the anodizing colour is different between the bikes, I am wondering about the clamping dimensions.
I have a 2022 CRF with a damaged top tube and they are on back order at the moment. I am considering ordering a set of Suzuki top tubes to replace and have the gold anodizing.
Thanks in advance!
Thanks in advance!
Top Clamp: 54mm
Bottom Clamp: 60mm
Clamping Area (Top to Bottom Clamp): 260mm
Overall Length: 564mm
Top clamp: 56mm
Bottom clamp: 59.6mm
Right side down
Here’s a picture of a 2023 KX450 fork on a RMZ450. The upper clamp surface diameter is 1mm smaller and will not work.
Post a reply to: 49mm Forks Suzuki, Honda, Kawasaki
