Jacksonville, FL
I apologize in advance if this question is out there and i've been unable to find it through the search option.
Making the switch to the Keihin and research suggested the 38mm was the size of choice. However, the insulator is of course 36mm and the 38mm Keihin does not want to fit in without force that i've been reserving applying.
In my research did I miss the section that discussed an adapter for the 36mm insulator? Do I instead need to apply a little more ass to make the 38mm fit?
That said, I apologize for the stupidity of this question, too.
Have you measured the carb spigot (the bit that sticks into plastic manifold). The new carb should fit, maybe that manifold has aged and hardened or something?
Agreed on hardening. They are a pain when the rubber has hardened.
OP, I believe I may have an 03 manifold (insulator) new in the bag if you’re interested. I’d have to look and let you know on a price. Bought it for my 02 and sold the bike without installing.
Post a reply to: 36mm Mikuni to 38mm Air Striker - 2003 CR250
