- Pick trends
- Create a private league
- And more!
Very few corners do I need to use 2nd gear but I think if anything I would go to a 51 on the rear and leave the stock counter shaft sprocket.
I ran a 51 on mine, not a huge difference, but was def for the better.
If not, sounds like the 52 is the way to go.
14/50=3.57
14/51=3.64
13/50=3.85
14/54=3.86
13/51=3.92
14/55=3.93
Not a huge difference but noticeable. Easier to pull some of the slower corners in 3rd gear and I use less clutch, does shorten 3rd gear up though on some of the faster sections.
I will be going between a 50 and a 51, as I don't think I need anything more than that for the tracks I ride.
Also, try riding with the #2 map (aggressive) and the Traction Control on or off. I prefer it off when its real loamy but turn it back on as the track dries out or if they water.
Might try a 52 rear w standard counter sprocket for more wide open tracks, but am pretty pleased with it as it is.
Next step is to put on an RD throttle body and Vortex ignition that I have on a 270 sxf. I understand that this bumps the low and mid quite a bit.
Post a reply to: 350 gearing
