10/28/2017 3:52 PM
Edited Date/Time: 10/28/2017 3:56 PM
Thanks for all the replies, I decided to dive into it today and just strip everything so I'm sure.
Crank is spot on, no play anywhere
Right side casing is all fine including clutch / primary gear ect
Piston looks good considering I do not know the history I would be happy to continue using it (I'm planning to sell the bike on anyways!)
Cam chain guides look ok, I don't think they are too worn.
The timing chance to me seems quite loose! It hasn't jumped since I've owned it (test rode for approx 2minutes) and had a lot of start/stop and revving trying to diagnose issue but has not been lapped around a track or anything.
I have a video of the chain here:
&feature=youtu.be
That is with the tensioner installed, the tensioner seems to operate fine how would I know if the tensioner is bad?
What is everyones opinion on the chain and how loose it is? Also can I re-use the base/head gaskets or will I definitely need new?
