8/12/2022 5:44pm
Me and my brother both got new 22 yz125 and ride on the trails/enduro but the plugs keep on fouling every half hour. Then read it was maybe the jetting so got a jd jetting kit which was recommended by lots of people who have the new 22s. That did not fix the issue but made it better. More throttle responce, more get up and go but the plugs were fouling still every hour on both bikes. Can someone please help me figure out what I’m doing wrong? And how to fix it!!
Specs (on 2 of the same 2022 yz125 bikes)
32:1 Yamalube 2r
Jd kit jetted for 0-3000 altitude
Always premium
Clean air filter
Under 10 hours both bikes
32:1 Yamalube 2r
Always premium
Clean air filter
Red needle
4th clip
170main
Shortcut would be to switch to a BR8 plug, and there is a real argument that it's ok and correct to do so for off road riding. But otherwise it's time to start real tuning beyond just the JD recommended specs. Trying different pilot sizes, mains, clip positions.
Also, and this will provably cause a shit fight, but 32:1 is too rich, especially for trail/enduro riding. I run 40:1 if I'm riding moto on my wife's yz125 and 50:1 when she's riding
40:1 vs 32:1 oil will make no difference to plug fouling. It is the fuel that fouls the plugs. If anything 32:1 is a touch leaner than 40:1. It will make a difference to how much oil comes out of the exhaust though.
On the general topic of oil ratio vs. jetting.....
Leaner oil/gas ratio makes for richer gas/air ratio. In other words, changing from 32:1 to 40:1 will be less oil.. but more gas. Which will cool combustion temps and make more spooge and more fouling. When people see spooge or fouling their natural reaction is to "just put in less oil" but it's not that simple and usually has the opposite of the desired effect.
What kind of oil are you using? Maybe in addition to getting it jetted right you can switch to a lower flash point oil. I’ve had great luck with amsoil dominator myself.
50 pilot still seems large to me however I have no experience with these new 125's. My 250, with that same carb i am running a 45 pilot.
Sounds crazy that those bikes come stock with a 72 pilot?
Air Screw: 2 out
Pilot: 58
Needle: NOZK (‘16 KTM 150 optional needle)
Needle Position: 2nd from top
Main: 162
Power Jet: stock
Slide: stock
Float level: stock
Fuel: 50:50 pump/C12 with 40:1 Motorex 2t
You're using, what I would consider, a really lean K starting diameter needle. I would almost suspect that you are off the straight section of that series needle and into the first taper, at idle. Combined with a rich pilot jet and a really lean, sea level elevation, main. You most be using a big/rich power jet to cover that. I guess if it works and you're happy with it, great.
70 Pilot
155 Main
3rd Clip NYDF Needle
I recommend honda hp2 oil. Cheap and ran much cleaner.
Post a reply to: 22 YZ125 fouling plugs
