- Pick trends
- Create a private league
- And more!
Usually the mark is on the back of the cylinder
If you still decide to do it measure the base gasket thickness so you can match the new ones.
I'm guessing kit I would be your first OEM kit, but 3bros Husqvarna would know best.
As AJ said, these bikes run a long time without top end service. I had a similar experience, replacing the first set of piston and rings in my 2017 KTM 250SX at 75hrs.
I'm at 75 hours, will probably pull/do top end at 90-100 hrs (C level rider).
On the last 300 I did for a friend I did see a mark though, it was kinda etched/scratched into the cylinder though.
I popped the plug out and head off and it said on top of the OEM piston. Measured the top.of the bore and ordered the same size again as it didn't seem to have changed (if I remember rightly, Vertex who are the OEM supplier did A, B and C on their aftermarket pistons instead of 1 and 2 though).
Double check any of this that sounds dubious or doesn't stack up, dont take it as fact, I've only been around bikes again recently and this is just what I've seen on mine, so I wouldn't want you put out by any oddities I've seen or mistakes I've made 👍
Good to know about the stamp inside the PV cover though.
Post a reply to: 2021 husky tc250 new top end help
